Dispatch, route visibility, and mileage workflows for IT field teams
IT field teams need more than mileage capture alone. MyCarTracks helps teams track travel automatically, dispatch jobs faster, monitor routes on a live map, and use location context to understand what happened at every site visit.
Best fit for: Field technicians, service managers, and operations coordinators supporting multiple sites.
IT Field Teams use case hero
Why this workflow gets messy without one system
IT field teams need to coordinate jobs, travel, and customer-site visits without adding admin friction for technicians.
Keep field work easier to assign, monitor, and report from one connected workflow.
Technicians are moving between customer sites all day, but many teams still treat travel logs, dispatching, and route visibility as separate processes.
Coordinators need to know who is closest, who is delayed, and what already happened at the site without calling every technician.
Without shared route and job context, managers spend too much time chasing updates and not enough time improving field execution.
How MyCarTracks fits this use case
IT field teams usually work best when dispatch, route visibility, and travel records are connected instead of managed in separate tools.
  1. Invite drivers and technicians into one workspace
    The app captures travel while the dashboard gives coordinators one place to manage field movement and assignments.
  2. Assign work and monitor progress
    Job Dispatch and live vehicle visibility help coordinators route work to the right technician faster.
  3. Review site visits and export records
    Managers can use route history, geofence context, and reports to explain what happened in the field without chasing manual notes.
What your team gets
Dispatch work faster with stronger live field context.
Reduce manual updates from technicians in the field.
Keep travel, route history, and site evidence easier to review.
What this gives your team in practice
Live technician visibility
Coordinators can see where field staff are and respond faster when schedules shift.
Site-level context
Geofences and route history help explain arrivals, departures, and time spent at customer locations.
Connected job workflow
Dispatching, travel, and reporting work better when they come from the same operating system.
Questions before rollout
Can IT field teams use MyCarTracks for dispatch and live tracking together?
Yes. Job Dispatch, Vehicle Tracking, and Geofences work well together when teams need stronger field coordination.
Is mileage tracking still useful for technicians?
Yes. Teams can still capture travel automatically for reimbursement or reporting even when dispatch and live visibility are the bigger operational needs.
How does geofencing help at customer sites?
It gives coordinators cleaner arrival and departure context and can support alerts or reporting around important locations.
What should IT field teams start with?
Most start with the SMB solution and Vehicle Tracking, then add Job Dispatch, Geofences, and Automatic Mileage Tracking as the workflow matures.
Ready to simplify it field teams work on the road?
Give coordinators better live visibility and technicians a simpler day in the field with one connected workflow.
